What prop do I need?
cbarger
I just bought a 1989 Javelin 171 bass boat. It comes with a Johnson Evinrude GT150. THe motor did not have a prop with it. What type of prop do I need? The dimensions and all that? I am new to this and I have no clue what to look at.
Re: What prop do I need?
You need to be in the PROP forum. There is no such thing as a "stock" prop. In fact new motors of that size are not even shipped with one since the engine builder has no idea what boat the engine will go on.
cbarger
Look I don't need a response like this. Keep your post to yourself. You know what I am asking. I bought a boat with no prop. I didn't say I needed a "stock" prop on it. I need to know like the what type of prop I needed. Like the right pitch, is there is a certian diameter size, width size and so forth.
MAC ATTACK
There is a section on this website that I used to learn about props. Up in the top there is a heading "boat propellers" that list props for sale. It has a lot of info on size, pitch and rpm levels.
If you search for your engine by year, size etc it will give you a list of props. The different pitch will be depending on your use of the boat......pulling skiers or getting all out top end.
I have a johnson 85 on a bass boat and I use a 17 degree prop. Works great for getting on plane and all around low and top end.
MAC ATTACK
you will need to enter the year of your engine, but it is probably a 15" diameter prop.
rndn
There are several prop calculator websites that will get you close. Unless someone on this forum has the exact same boat and motor combo, all will be a guess.
