Re: What Prop and Where!!
Tandg96 -- when someone asks what your WOT throttle rpm is, they mean what RPM do you "observe" on the tach at WOT -- not what the manufacturers recommended WOt RPM is. When selecting a prop, the prop you choose must allow the engine to operate at the manufacturers WOT rpm band. If the engine will not reach that rpm, that's an indication of too much pitch. If it exceeds that rpm band, you need a prop with more pitch.
