Audiogod21
Thread starter- Joined
- Jul 13, 2010
- 9
Hello please bare with me for I am not very good at this, here it goes...
I have a 2000 Crownline 202BR with the mercruiser 5.0 2BBL 220HP Alpha one Gen II outdrive the boats weight is approx 3500lbs with a full tank, and i usually go out with approx 5-6 full size adults.
The current prop i am running is a mercury blackmax 14.25X21P full speed trimmed out is 43mph @ 4800 rpms. I need help choosing the perfect prop for i don't want to make a $400 mistake. I do alot of cruising and some watersports as well i would like to upgrade to a SS prop. Don't know weather to stay with a 3 blade or upgrade to a 4. Do I need bow lift or stern lift? High rake or no? Increase diameter or stay the same? So many choices :facepalm: . I was looking at moving to a 14.25X19P SS Stiletto Bay Pro III 4 blade but not sure what it will do for me. I was also looking at the SS Stiletto Advantage III 14.25X19P 3 Blade. Curious about the 19P for sure because I've read on here about moving down 1" down in pitch size for going from 3 blade to four blade and also 1" down when upgrading to SS not sure how true the SS 1" drop is. Ayuh
Can someone please help? I hope i have provided enough info if I forgot anything please let me know. Thank you all so much for the help...
