I've posted about my boat on here and now it's time to move on with some transom repair work. I have 4 , 3"x3" holes that are down to the plywood (by my doing for inspection purposes) that need covered. I want to paint the back end also once I have this all complete so it doesn't look so junkyardish with 4 or 5 patch marks hehe.<br /><br />Please suggest products that Iboats carries as I need to pickup a manual for my engine, carb kit etc etc so I want to get it all from the same place possibly. <br /><br />I posted about this and it seemed to be correct that I needed to put down poly, then mat, then two more layers of poly, then a filler? Is that correct? I just want to be sure. Also WHAT products should I use. The mat should be 1.5oz correct? What poly should I use and what filler? <br />ALso - what paint? <br />Ive seen ALOT about epoxy and poly...many saying that epoxy is better but others saying it wont bond to my current plywood and gelcoat etc? <br /><br />Also my flooring has fiberglass showing in many spots where the paint has begun to where off, also on the side inside the boat. Suggestions on floor/side paint please?<br /><br /><br />OH BTW - I have only one area that will be under water, the draintube area. I am going to have to chunk out the rotten wood around the draintube which is small, but it will need to be filled and reshaped, etc....suggestions?<br />Thanks guys..<br /><br />S
