What Outboard is this
tosha
Hi ya'll, I have been lurking around for a while and have used some great tips from this forum. I am hoping you all can help me out. we are lookin at a 1990 Alumacraft Pontoon boat I think we can pick it up on the cheap but I am having alot of trouble finding out what motor is on it. the numbers are 90 ELPT and 0E329342 it also had on the sticker 5250 max rpm. I can't determine if it's a 2 or 4 stroke or 3cyl etc... the boat has been sitting for a while and the cushions are in bad shape. the deck is solid and it comes with a double axle Moonshine trailer. we are going to start it this afternoon and if it runs well we will water test it and I will take it to a mechanic to do a preinspection. just wondering if ya'll could help me out. also the boat number is
ACBA5020K990... what's it worth??
thanks in advance
tosha
lncoop
Re: What Outboard is this
If I were guessing I'd say it's powered by a three cylinder ninety horse Merc. What it's worth depends on a whole list of considerations, but offhand I'd say not a whole lot. It's an old barge made by a john boat company and based on your description needs some work. Here's what I would suggest. If you haven't already, browse the pontoon section to get an idea of what you need to look at/for on the rig in order to keep from throwing away your money. Once you've done that, start a new thread over there that provides as much info as you can muster: location, price, size, how you plan to use it, etc. If you could post a link to the ad that would be very helpful. Good luck tosha.
tosha
thanks for the quick response. I will do just what you said. I am starting to lean to the not side of things ... just looks like too much work, but I'll keep ya posted.
