What motor do I have?
SMCSullyman
A firend of mine gave me a older Evinrude motor and I'm a little confused to what it is. The cover on top says that it's an Angle 5hp, but the serial number is 3802A-0E01661. When I looked up the model, it says it's a 3hp Lightwin made in 1968. I looked at pictures of both the Anger and the Lightwin and mine appears to be an angler. Am I missing something? I will post pictures when I figure out how.
Chinewalker
Yours is the Angler, 5hp. The Angler was a budget motor, using the 6hp powerhead on a direct drive 3hp lower unit. With that in mind, it is entirely possible your motor has had the clamp bracket, with serial tag in tow, replaced at some point in the last 45-50 years. The model number may also be located on the nickel-sized plug on the cylinder block, starboard side.
Going by the decals, I'd peg it as a 1967.
