I've got a 2000 Larson 234 Escape. The driver's chair is a pedestal type chair that is screwed into the fiberglass deck. Last year I noticed that a few of the screws were stripping out and coming loose. I tried putting some fiberglass epoxy into the holes and putting the screws back in, but it didn't help much. The screws are under a significant load fairly often because passengers regularly pull laterally on the driver's chair.
I would like to add a panel to the underside of the deck and then run bolts through the deck and panel to secure the chair. By removing a storage area, I should be able to get a 2' x 2' panel underneath the deck. A couple questions:
What should I use for a reinforcement panel? Plywood? I'm looking for a material that will distribute the load over a greater area of the deck.
Any reason why the reinforcement panel wouldn't be a good idea?
