rwidman
- May 27, 2004
- 1,396
Re: What makes a trailer start to sway?
Get your tongue weight set correctly, make sure the trailer is level when connected to the tow vehicle, and make sure the tires are inflated to the maximum pressure indicated on the sidewalls.<br /><br />As for passing busses and trucks, you're not going to be able to outrun them so keep an eye on the reaw view mirror and let off the gas when you see them comming. The real fun is when they pass you on both sides at the same time going 80mph!Originally posted by BoLin:<br /> We just brought home (to MD) a boat (20 ft Grady) that we purchased used in NJ. We did fine except whe a semi or especially a bus passed us. The sway was very scary, but we just eased up on the accelerator and were able to get through each episode.<br />If the sway only occurs with passing buses, should we make any of the adjustments mentioned above or are they not going to make a difference?
