What Make & Year & Horsepower
fmalott
Model# J70ELCTE
SERIAL# C8172294
runs for 30 minutes than stalls
Daviet
Re: What Make & Year & Horsepower
1983 70hp
Does it run out of fuel, loose spark?
When it quits does it shut down quickly like you turned off the key, or slowly like you are running out of gas?
fmalott
like your running out of gas the fuel line goes empty
Daviet
If you pump the primer bulb will it start right back up? Maybe a fuel pump problem. Are you running on an inboard tank or a portable 6 gal tank?
fmalott
pumping primer bulb does not help feels mushy i'm running on a 6gal tank
fmalott
should i look at the primer and the fuel pump i'm going to rebuild fuel pump but can someone explain what happens when you prime at the begining run the boat for a bit what should the primer be doing during running time and when you stop the motor also does the primer stop the fuel from going back to tank my problem is when boat runs for a bit it stalls like running out of gas and the primer ball is mushy i'm running from a 6gal tank
fmalott
is there something maybe wrong with one of three carbs or maybe something over heating or just what's in post above
