What kinda spark plugs
BigPoppaG
Looked in the manual but not mention of spark plugs. Any suggestions on what kind I should use? 1999 3.0L Mercruiser I/O :)
BigPoppaG
Re: What kinda spark plugs
Are they just standard sparkplugs or is there a certain size needed?
crazy charlie
I prefer NGK but they usually cost a little more.Mercruisers do well with ac delco too.Charlie
ron7000
Banned
AC-MR43LTS or NGK BPR6EFS<br /><br />this is out of mercruiser service manual #26, for that motor.<br /><br />they are standard plugs (all plugs are the same really) and can be gotten/ordered from most part stores.<br /><br />Cross reference would be a resistor plug that has 14mm threads, 0.708" reach, and the coldest or next to coldest heat range.<br /><br />I think the Bosch equivalent, according to my NGK cross-ref table, is HR8DCX stock #7571. From there you can get to finding the platinum versions if you care to.<br />Some others are Autolite AR103, Champ RS9YC stock #304.<br /><br />NGK TR6 will work, they are more common, but I've called NGK and couldn't get a definite where their heat index is compared to the BPR6EFS. They seemed to run a little hot in my 3.0L but that was back when I had carb problems, and I haven't tried them since. My recommedation is to stick with the AC's, they are a good plug, easy to get, and should only be $2 each. If you try other than the AC delco's, be sure to check them frequently for signs of running too hot.
BigPoppaG
Thanks for the info Ron and Charlie. You guys have been a big help.
MH9371B
Yep, got it straight out of a Clymer manual for that exact same engine.
