What kind of line?
CalicoKid
Re: What kind of line?
For cutting up weeds braided is tops. For all else I am really digging Suffix Seige on my baitcasters and Suffix Elite on my spinning.
Plainsman
Have you tried contacting some of the companies and asking for samples? I'm sure some would to try and get your business in the future.
LubeDude
bassboy1 said:
One spool of the spinning reel is gonna be filled with some 14 mono which I got for renewing bassmaster magazine.
Something that many don`t understand about spinning reels and line is this.
It depends on the size of the spool on the reel what # line you can use without tangles. If you have a 1000 series reel, floro over 4# is likly to cause problems where you could get away with 8# using a mono. A 10# braid or even heavier will work also because the braids are so limp. I have seen very few spinning reels unless they are saltwater size that will work well with 14# anything but braid. If you are going to cast heavy baits like a 1/4 to 1/2 oz jigs or spinnerbaits you might be alright, but if you try a weightless plastic you are going to have tangles. LIve and learn.
bassboy1
I have never had trouble with large mono on a spinning reel. I have had one spool filled with 6# and the other w/ 17 # for as long as I have ha the reel. The only issue I have had w/ the 17 is knots comin' untied. Then I changed to the palomar and all is well.
LubeDude
Your reel must have a rather large spool. Or you are using heavier baits with the 17#.
jtexas
I've seen 14# mono leap off the spool at every opportunity and sometimes it lays there no problem. it never occured to me to put 17# on a spinning reel - kinda defeats the purpose of spinning which for me is to use lighter lures.
bassboy1
Ya, that was before I had my baitcaster. Now, it will be for the smaller ones.
teamADR
I would use Mcoy 8 lb mean green it the stongest mono I have ever seen
