what kind of boat?
glindsey1114
does anyone know what kind and year this boat could be? the boat says winner on the side and formula on the windows.. Can't seem to find model type for it?? Please any help would be great... can't seem to find anything on the boat that lets us know...
david_r
Re: what kind of boat?
you can use the hin numbers to at least find the manufacturer
heres a link http://boatsafe.com/nauticalknowhow/hin.htm
use this to get your letters then go to the bottom of the page and you will see the coast guard "click here" thing and it will take you through the steps to find the manufacturer.
one of my boats that i couldnt find anything on using the name on the side was made by performance products manufacturer................. i wondered why a guy had a boat identical to mine (less the color) and his said performer and mine said venture
hope this helps
david_r
welcome to iboats!!!
i just realized you were new
rbh
The HIN on our boat is stamped into the fiberglass on the transom.
rob
ezmobee
I wouldn't worry about it. That giant cardboard box will probably be finished eating it by the time you figure it out anyway... :)
ezmobee
Hopefully the box monster at least leaves you the trailer!
david_r
did you find the hin?
they should be on the upper starboard side of transom......... sometimes they are on plates and sometimes they are stamped like rbh said above.
after you use the hin to get the mic (first the letters) you can find out more info using the links posted...... hopefully the manufacturer isnt out of business.
david_r
i tried my links while helping another member and found not all the links went all the way through for some reason so heres where you can use the mic numbers......... after you pull up the mic click on the mic numbers to get all the information available.
heres the coast guard link
http://www.uscgboating.org/recalls/mic.aspx
