What is this?
dave181024
This is a picture off my 1988 OMC 4.3 Cobra. Wondering what this screw is...seems like it was just sitting there and not attached to anything. Anyone have any idea it would help out alot. THANKS!!
Re: What is this?
Ayuh,.... That's OMC's Majic Screw,.... Don't touch it, you won't like the Majic that happens....
dave181024
Re: What is this?
seems someone already touched it...what does it do? what is is called? what does it thread into?
Bifflefan
Re: What is this?
It does nothing.
It screws into a special nut on the inside of the drive that falls off then you try to remove it. you have to remove the lower unit to get the piece out and put it back on and you cant run without it.
Just forget about it and you will be better off.
airdvr1227
Re: What is this?
Better than forgetting about it get a paint stick and write in big letters "DO NOT REMOVE"
dave181024
Re: What is this?
I wish it was that easy...someone removed it and now the nut is lost in there and they left the screw sitting in place.
I'm going to drop the lower part and get it out...do i need to remove the whole outdrive to put the screw back in?
dave181024
Re: What is this?
if this screw isn't on tight and i'm starting the engine w/ the muffs could this be the reason why the water isn't making it to the thermostat and spitting right back out the bottom?
ryanorr280
Re: What is this?
if the water ins't getting to the motor, i would put in a new impellar just to be safe, or at least take a look at it.
starsnstripers
Re: What is this?
Mine had that hole and all they did was put one of those adjustable "T" rubber plugs in it. It's a water cavity and with the removable plug you can drain it in cold weather.
