What is this on my transom???
kdmiller8251
Hello All, I have a question I hope someone can answer. I have a .<br />on the transom are two grey round "things" I do not know what they are, and they are screwed into place. They look like plastic spray can caps turned [/IMG]
crab bait
Re: What is this on my transom???
scuppers..?? <br />they have a flap or ball to let water out but not in...
kdmiller8251
Nope there are no holes in them just one open end which you can see they dont go anywhere....
roscoe
Imitation dual exhaust?? Reminds me of a '69 Plymouth Road Runner. I'd take one off an see if previous owner hid his gold behind it.<br /><br />?? Good Luck, let us know what you find out.
kdmiller8251
If theres gold back there you wont be hearing from me again... HA HA...
Trent
Are their wires hooked to it on the inside of the boat? If so, my guess is MerCathode System or an aftermarket type. But if they are REALLY wood...? I dont have a clue.
Mikedg
If you can't get your answer from the gang here, try contacting Regal Customer Service at www.regalboats.com. They've been helpful in the past with questions regarding my Regal.
sloopy
matbe there there to make shure you don't turn the drive too much... I am soooo stumped
tmcalavy
No, no, you're all wrong. This is an obvious retrofit...left over bat pipes from a redo of the bat boat. Holy Catfish, Batman!!!
Mumblerone
We need a better picture...a real close-up. :confused: On the other hand, maybe you don't want to get to close. :p :(
Jack Shellac
I'm not even willing to guess. Have never seen anything like it. Please let us know if you find out.
kdmiller8251
No wires attached to them, just a few screws to screw them into the transom and thats it.....<br />I saw another boat exact same as mine but that boat did not have these. So I dont think it came from the factory. These things do nothing, drive does not even come close, hmmm. Well I guess it was worth a shot..... thanks for the help folks!<br /><br />tallman
SCO
Might have been added on to hold the outdrive up if hydraulics were leakey or for tilt cylinder service???
blifsey
Are there any holes (w/threads?) around the side that would be used to secure a pipe or something that slide into them? If so, that would tell they a are made for "holding" something in place like a swim platform, etc.<br /><br />Oops, just noticed you said they might be wood. That makes it even more strange.<br /><br />Perhaps a previous owner had problems backing his trailer and they are "boat bumpers" :D
Reel Appeal
Ok, I'm gonna take a wing at this...<br /> First question,does the outdrive trim work?Was the outdrive replaced?I see a strap going to the swim platform attached to the outdrive(why I ask),like it's holding it up.Those things on the transom could have been part of a removable homemade bracket to hold up the outdrive while traveling.What are they made of?
kdmiller8251
No the strap in the picture is to hold the cover on... No holes, no straps attached, no threads nothing on these things..... The Mystery continues... They have 0 mechanical function, only held on with three screws and thats it, dont look like they would support much weight... if you want to see the whole boat <br /><br /> http://www.kdmiller.com/boat.htm <br /><br />Tallman
