What is this? Help
sfutchko
Hi all,
Is this a choke solenoid ? I can't find any online that resemble it. I removed it because when the power is on it gets really hot and starts to smoke. I can smell it burning. So I want to replace it.
It's on a 79 115 v4 Johnson 2 stroke.
Thanks for the help
Fed
Google the part number & you'll find it. #
0581929 ​
Fed
A little word of caution, I've found that any solenoid powered up without the plunger (armature) pulled fully in will burn out right before your eyes so be careful with any linkage travel adjustments and make sure it's all free and assembled properly.
Look for the equivalent evinrude manual at the library http://boatinfo.no/lib/library.html
interalian
Yes, that's a choke solenoid. I have one from a '79 140 that I'll never use. If you're in Canada I'll mail it to you for free.
emdsapmgr
part number 581929. Obsolete and not available from the factory. There are a number of factory dealers that still have some new stock still on hand on this part. See this dealer-he has 5 still in stock: new. Give them a call and they will ship one to you.
US BOATWORKS INC930 OSAGE AVEKANSAS CITYKS66105-1850913-342-0011usbw1@cs.com0581929
Crosbyman
make certain the choke activating switch is not stuck ON..and releases properly . heat and smoke indicates power is being applied constantly and a choke coil normal operates a few seconds while starting
​AS per FED #3... make certain it mechanically works... try a bit of WD40 to free it
