What is this and what does it do? (see pic)
Re: What is this and what does it do? (see pic)
There is a black plug in the stern drive what does it do?
Ayuh,... Where,..?? On What Drive,..??
Lyndy
Looks like a a pre 72 OMC High Profile drive with a steering arm. I have a hole just like that one on mine but it does not have that plug on it. It does not look standard and I have not seen one on any stringer I have looked at on this forum or on other forums. :confused:
JustJason
ahhhh.... that's a bilge drain plug.
What it's doing on the back of your drive though... I have no idea.
Lyndy
Might be a good place to hang the drain plug when not in use
Chris42069
Its a OMC 140hp I took out the plug and it smelled like exhaust. I changed the water pump and thought it would tie into it but was bone dry.
windsors03cobra
Lookie like a plug holder from the innovative folks at OMC ? :rolleyes:
Fishermark
I have an old boat with an OMC outdrive by the side of my shop. It is an old electric shift, but it appears to have a hole where your's is plugged. You can kinda see it in the picture below:
When you take the cover off that has the hole in in, there isn't much underneath:
That may or may not be helpful... but at least you can see what is beneath that cover! ;)
ziggy
just a wag... if that was a outboard, and w/o any experience on it, i'd expect water to be spiting out of that hole. not have it plugged... like i say though. i have no idea other than this wag...
Chris42069
I had the lower unit apart and it seems this does not go far and I did not spit any water out. I thought it might be a attachment for a garden hose or something like that. I notice on the side of the trim there is a cover for the hose attachment mine does not have that.
