- Jul 23, 2011
- 52,191
Re: What is the trick to find an elusive oil leak ?
$1000 for a $40-$100 DIY fix. you figure it out? if you do not want to do the labor, then you have to pay someone to do the labor. I myself would pull the intake and go from there.
However if your leak is on the left side of the rear of the engine, you may want to really double check your oil sender first to see if your leak is not coming from there vs a manifold or head leak.
