what is the correct torque for omc 3.8l 229ci?
hz
I asked this previously but got no response.
Does anyone know what the torque should be for the head and intake manifolds on an OMC / Chevy 3.8L 229cid. This is on a 1983 Seaswirl 19ft. Thanks,
Harris
KaGee
Re: what is the correct torque for omc 3.8l 229ci?
30ft/lbs on the intake, 65ft/lbs on the heads.
On the heads, tighten to about 35-40 first round, then go back around to 65.
If you need the sequence, I'll have to copy the pictures later.
PS... Don't forget to use Permatex #2 on the headbolt threads.
