What I used was a razor to start them and as I lifted them. For the most part if your carful you can pull off whole strips then I just went over the area with acitone.<br />Go slow and be careful as a razor can do damage.<br />AlexOriginally posted by KaGee:<br /> What i meant was... will oven cleaner work for taking off trim tape??
I went a got one of those scrappers that take the razors blades and found if hold it flat against the fiberglass it is easy to slide under the tape helps also to prevent nicking. but mine to came off in 6 to 8 inch lenths as well. I was lucky enough to have all mine on flat surface with room to spare go slow and you should be ok.<br />AlexOriginally posted by KaGee:<br /> The problem is, my stripes are cracked, they will never pull off whole. Come off an inck or so at a time. My son got off one, but like you already warned, did a good job knicking up the gel.
