what is the best way to fill small holes in aluminum?
jtrom
I was thinking of using a piece of tape over the back, then filling the hole with JB weld, then removing the tape, then sand it flush on both sides. I don't want a permnament backing plate. Is this a good and lasting repair? (the size of the holes are less than a 1/4 inch)
jigngrub
Re: what is the best way to fill small holes in aluminum?
I personally like Tite-loc marine epoxy... very durable.
How many holes do you have?
Is your hull riveted? If it is you could just stick a rivet in the hole and no one would ever notice the difference.
This is an easy way to fix holes and leaky rivets.
http://www.youtube.com/watch?v=L0MA1-5NXjs&feature=related
jtrom
Yeah I was gonna use rivets for some of the holes (there are about 20 holes) but some of the holes are in places where a rivet looks out of place
jigngrub
Did somebody shoot that thing with a shotgun or what?;):D
jtrom
Haha...nope....just stuff being mounted and taken off over the years (the boat is 52 years old). I also removed both wood benches...that is 12 screw holes right there
jtrom
Yikes...I meant 24 screw holes just for the seats...maybe I have mistaken this giant cheese grater for a boat!! Haha
tgp***
My Nassau had more holes and dings than I could count. I used JB Weld Industial with a piece of aluminum flashing on the back side. I coned out the topside of the hole with a drill bit first so there is a little holding area. JB Weld adhears really well. The stuff dries really hard, difficult to sand down, but once its done its a solid fix.
Bob_VT
Use rivets........ only you will notice. The jb weld and or epoxy are okay however, I have seen the stuff pop out under flexing.
Pop rivet coated in 5200 and it will never leak.
djpeters
Your title asked for the best way, IMHO, have them welded up by a qualified welder.
