what is the best steering for under 150.00
bigmcgiv
looking for options for my nassau. i would like to use the orignal wheel.
barato2
Re: what is the best steering for under 150.00
Uflex rotary, much cheaper than telefix and just as good. orig wheel should fit since all boat wheels i've seen yet use the same tapered shaft.
jbcurt00
If your Nassau has the small flat shelf under the dash & you plan to leave it, you need to get the bezel adapter to make sure the steering wheel (&/or your knuckles) don't rub/hit the edge of the shelf....
tgp***
I used the original cable pulley system. Sill good after 3 three years. If it needs new cable its under $20. Just remember to use real heavy duty S hooks. I ended up going bigger after the first year. Steers like a dream.
crkranz
Teleflex rack system was cheaper $25 when I was looking. Whole kit was around $130.
