What is the best Gasoline for 1976 Outboard Johnson 70 HP?
aulet76
I was told that I need to use gas that is unleaded or with lead, not sute what is the best octane either. Can some one tell me what is the best gasoline for my boat? again is a 1976 Johnson 70 HP. I dont have th serial of a hand, I can get if need it.
Re: What is the best Gasoline for 1976 Outboard Johnson 70 HP?
Regular Leaded or unleaded gasoline is fine. I would use regular unleaded as it will be easier to find. Mix with TCW-III @ cycle oil at a 50::1 gasoline to oil ratio.
rockyrude
I'm not sure if you can even get leaded fuel at the pump any more. 87 octane regular will be just fine for that motor. If this motor hasn't run in a while I'd go through it an replace ALL of the fuel lines with the ethanol resistant fuel lines. Most likely you will run into a fair amount of it. It will save many headaches down the road.
Philster
Don't older outboards run the risk of running lean on modern ethanol blends unless adjustments are made to compensate?
Chinewalker
I've never had a problem with any of mine running E10... I even read my plugs periodically to make sure everything is kosher inside... No sign of lean condition in any of them.
Home Cookin'
the E10 itself isn't an issue, especially for a workhorse motor like that, if it's fresh. The problems (often debated) come when the E10 gets some age to it, which can cause it to break down, or over time, attract water, or loosen gunkified stuff in the fuel path since it's an efficient solvent--the loosened gunk causes the problems, not the fuel itself.
Also, because of its higher alchohol composition, it can cause older parts such as hoses and fiberglass tanks to degrade, again sending gunk through the fuel path.
One reason it seems E10 is hard on boat motors is because boat fuel typically isn't all used up in a month, like cars' fuel is. Same with motorcycles. Second, the smaller the motor, the harder to handle the gunk and water. Third, a boat's tank is exposed to more humidity than a car's, so those who agree that humidity is a problem with E10 point to that distinction.
For general recreational use, especially in an old 70, any difference in how E10 performs v. pure gas would be negligable.
I'm doing my level best to describe fairly, rather than advocate, the opinions as to E10.
cyclops2
Banned
No chance of a tight ring or piston. :)
Reading sparkplugs is better then ANY computerized instrument.
Is the instrument accurate ?
Your eyeballs & the color of the plug insulator NEVER make a mistake and are always calibrated. Free carrying case is provided.:D
That engine is loose enough to run very safely on 50 to 1 regular gasoline mixes.
The lead was for the hot exhaust valves & valve guides.
Remember when Lead ended ? They had visor signs warning about not to let the car idle for long periods of time. Never said how long was too long. :confused:
pecheux
As per my Merc mecanic advice ... I like to run my older OB's with ethanol free high test gasoline (from Ultramar) but I have no proof in the pudding that it's necessary. But with 9.9hp and 15hp I dont use enough to care ... LOL
rockyrude
Running ethanol free is the first choice, not everybody gets that choice. The octane rating of regular has been the same almost since the beginning, running higher octane is just a waste of beer money.
cyclops2
Banned
There was a detailed thread about the good & bad things of low & high octane gasoline in regular gasoline engines.
High octane gas burns SLOWER to prevent detonation / pinging.
It also burns hotter due to the slow burning . ....Anyway the end result was burning high test in a regular engine was not helping the engine in anyway. Plus you get less power & milage due to the slower burning rate.
Some others must have read that posting also.
