Re: What is DVA
Would you believe it if you saw a Multi meter at Harbor freight and tool with a PVA in it for $14.99 ?
I actually bought one for $2.99 I wanted to see a digital read on My battery , before And after start for a general Idea if it was charging . BUT the $2.99 one will work for about 1 minute on a battery that is over 10 AMPs , But it showed me a pre start 11 volts ,... Engine running 13.7 to 14.1 volts variation ,I suppose this means it's charging , But the darn thing blew the fuse . So I suppose I will try the $14.99 one if I can see that it handles the AMP of an out board , do You know what AMPS the meter shold handle ? or is it too good to be true that a multi meter will work for 14.99
