What is best epoxy for aluminum casting?
Mark42
The kids go kart uses a Peerless differential - common diff used on many small riding mowers, but in a 1" axle size. The "cone" shaped part of the differential housing on one side cracked and broke off. It is a cast aluminum housing. Before I order a new case half (about $60 plus shipping!) I thought I would try some epoxy and see how well it holds up.
Thought I would ask here for epoxy input! I'm thinking JB Weld might be the way to go. Or maybe Marine Tex?
BTW this is the second time this case half has broken. It happens when the kids get the kart air borne then when it lands, CRACK! The axle is only supported by 1" bearings at each end by the tires. To prevent this from happening again, I'm going to add additional bearings to the axle on each side of the differential, so there will be little or no stress transferred to the differential housing.
You can see the setup in this photo:
Its an old Rupp go kart from 1970 that I modified for "off road" use. Even though it only has a 5 hp motor, with the torque converter trans and the low gearing, it will climb steep inclines at tops out at about 25 mph. Its just too much fun!
bruceb58
Honorary Supreme Mariner
Re: What is best epoxy for aluminum casting?
You can get it TIG welded. You have to use a certain alloy filler rod because it is cast.
Ask your question on welderweb.com. There are many knowledgable people on there that can answer your question.
WillyBWright
Marine Tex is my preference, but JB Weld is easier to find.
rwise
The electric glue would be the best if the welderdoes a good job. Looks like a lot of fun:cool::cool::cool:
