Re: what is a looper?
It has to do with the the way the fuel mix gets into/out of the motor. There are two ways the the mix goes in/out. The older motors were cross flows, when the piston goes down it opened both intake and exhaust ports directly opposite each other in the cylinder, causing a "cross flow" across the top of the piston. The newer motors have a "dome" on the piston causing the mix to "loop" over the top, the looping does a better job of getting the exhaust out and fresh mix in with resulting better fuel economy.
