What is a dashpot used for and is necessary anymore?
Zeb
I have a 1982 Mercury 25 HP and is missing the dashpot. Do I still need this? If so, where to find one? If not, are there any adjustments that need to be made with the idle because of this part not being there?
Thanks
Zeb
Re: What is a dashpot used for and is necessary anymore?
Dashpots are an air cushioned device that facilitate a smother or more gradual decline in throttle from a running speed to idle. If your idle stop screw still touches the cam upon which it sits at the rest position, the motor should operate without the pot. However, a reduction in your throttle control will probably produce a faster slow-down of the engine and could feel rather jerky without it.
If you want to have the pot back on, there may be some universal ones at NAPA etc if the original replacement is not readily available.
Hope that helped.
