what im i doing wrong? spark.
Dborun
i got a 64 evinrude 40hp ...so i bought new tune up kit because bottom cylinder was not giving me spark. i replaced all but i still get no spark on same cylinder. any ideas?i also swaped out wires and plug. but still no spark on bottom plug. ive search forums and here but cant seem to find whats wrong. i attached a pic. red wire to top cyl coil going to ign and bottom coil going to cutout switch.
hardwater fisherman
Have you checked the coils? If they check out maybe you need to check the plug wires. Did you clean the points? EDIT make sure the plug wire is screwed in correctly into the coil.
Dborun
yes cleaned even swapped points. i swapped plugs and coild and still same issue no spark on bottom plug.
HighTrim
Start by ensuring the coils are good. A mercotronic is best, but you likely do not have one, so simply ensure the primary and secondary windings are not severed. If you need help with that let us know. Simply hooking a meter up between the plug pin and ground lead (secondary) and then ground lead and points lead will test this.
If the coil is good, you also need to ensure that the condenser is good. If you got a new tune up kit, you should be ok here.
The points need to be CLEAN. I'm sure you know what you are doing, but everyone's definition of clean is different. I have had a few guys from this forum bring their motor over that did not have spark, and they stated they cleaned the points. Well, spraying contact cleaner at them through the flywheel is not really cleaning them. They need to be polished with a points file or the like, then cleaned with acetone, after setting the gap at 020 when the rubbing block is at the widest point of the cam as mentioned above. Even when new, they often come with a haze on them.
Ensure that the plug wire has good continuity, and is threaded into bottom of coil.
Ensure that spring clip in the spark plug boot has good contact with wire, and is not corroded.
Set the air gap for the coil heel, so that the lamination does not rub on the magnet, but is very close to doing so. You need to pull the coil outwards, so that the lamination lines up with the flat boss of the mounting tab on the mag plate. You should be able to run your fingernail up the boss, and not have it catch on the coils laminations.
Ensure that your kill circuit and/or the vaccuum cut out switch is not grounding out the ignition system.
After all of this, the spark should easily jump a 1/4" gap on an adjustable tester with a bright blue ZAP!!!!
Dborun
ok ill try all that shortly. can i take mag plate where the coils and poibts mounts and clean with carb cleaner just to degrese everything?
oldboat1
If referring to the top of the plate, I would just spray it off with electrical cleaner if you feel the need to clean it. But if you do that, dress the points afterwards like High Trim describes.
Just for additional basics on gapping points, the cam with the lobe is keyed to the shaft (can see it all in your first pic). You turn the shaft until the lobe contacts the the little red rub tip on the points arm -- set the point gap to .020 when the shaft and cam are in that position. Then rotate the shaft clockwise until the second set of points opens.** Gap that set of points to .020. You should then be good to go as far as point gapping is concerned -- can certainly fine tune, but likely very close.
Turn the shaft either by turning the prop clockwise with your foot (motor in forward gear), or temporarily putting the flywheel on over the key , and turning the flywheel clockwise. After setting the points as described, you should see spark -- can test by setting the flywheel in place temporarily, and check with plugs out. With your spark tester hooked up, spin the flywheel by hand two or three times and look for spark. You do not need to torque or bolt on the flywheel for this procedure.
[ed. **that's 180 degrees -- half a turn]
HighTrim
I do that on every motor I restore. Mag plate comes right off, all old grease and grime is cleaned off after a long soak. Then new plug wires are installed, and a new THIN smear of new grease installed. Not too much, or it will fly off and foul the points. Much nicer to work on a freshly cleaned mag plate, plus less chance of points getting fouled by old grease and grime.
