What hole gets the rod?
special_kaye
Hey all,
got my new-2-me motor and it has two places I can connect my steering rod. Which one do I use? Does it matter? Should I use the one the gives the best arrangement for the steering cable?
BTW, this is an 88 Suzuki DT150 Super Six.
Okay, now here's a funny one for you: This picture is essentially the same motor, just a bit older but also a Suzuki, this one just happens to be a DT200 instead of the 150. Same engine. Same block even, if I remember right. But, the older, bigger one does not have the second steering connection.
Thoughts, comments, opinions greatly appreciated. I really need to know which hole to stick it in.
freddyray21
Re: What hole gets the rod?
don't know that it would matter, but my inclination is to use the outer hole.
F_R
Honorary Supreme Mariner
It does matter. Use the one closest to the motor. The outer one is for a dual engine tie bar.
It matters because using the outer one will not give full steering arc.
special_kaye
Try to learn somethin' everyday. Thanks. I learned somethin'. Never even thought about that. Much appreciate the response.
