Re: What harm does lugging do?
Well, to start with, if your engine is only hitting 5300 RPM, it is not producing its maximum horsepower, rated at the 6000 RPM speed.<br /><br />Bottom line here is that if you have a prop that allows the motor to reach its rated WOT RPM, you will proceed on the water at a faster rate, since your speed on the water is more or less directly related to the RPM of the prop and that prop's pitch.<br /><br />If you can turn a prop at 6000 RPM at WOT, you will be generating more HP from the engine, and will go faster. Going faster is always good.<br /><br />On the other hand, I never run an engine at its maximum RPM, except perhaps in short bursts.
