What glue do y'all use to stick vinyl on aluminum?
lakelover
Just some good spray contact cement? How does it hold up to the sun & heat? I want to apply vinyl to my dashboard tray. Thanks.
jesusn
Re: What glue do y'all use to stick vinyl on aluminum?
pl man it sticks to anything and stays that way even in water
Stratosman86
I used Weldwood contact cement and it has held up well for me.
Darren
ajgraz
Darren
Get the Weldwood in the red can (the original formula), not the low-VOC junk in the green can...that stuff just don't work fer crap.
lakelover
I find a lot of the green versions don't work well, so while they may be easier on the environment, what good are they?
Stratosman86
AJ, you are so right. The original is the best.
Darren
Bob_VT
I glued indoor outdoor carpet directly to aluminum using the Home Depot 6700 and that would work fine with vinyl....... it's cheap too ;)
lakelover
It's cheap all right, but I don't know what I'd do with a gallon of it! :)
Bob_VT
No no it comes in a small quart container too
lakelover
Heh heh, I did a quick look on HD website and the gallon came up. Will definitely check out the smaller size. Looks like pretty good stuff.
