What Fuel Pump Options Do I have?
dezmond
Hey Everyone :)
I am just about ready to put my Mercruiser 120 Engine back into my boat. I fabbed up some new motor mounts for it as it is going into a Bayliner Capri. I have the old style Carter Fuel pump with diaphragm and I wanted to get a service kit for it before I install the engine. It sat for 7 years so I figured now would be a good time to do it. I am finding out that parts are almost impossible to find for this pump. Could you offer some suggestions as to what else I could use for a fuel pump? or where I might be able to find parts for mine?
Thanks in advance!
Dezi
dezmond
Can I get a service kit for the one I have?
you may be able to search around for the seldom purchased service kit and find one or you can spring for a new pump.
the serviceable fuel pumps went away because no-one serviced them. they simply replaced them.
If your heart is set on the rebuild kit, I would start googling to see who may still carry the service kits.
dezmond
Ok... So what would be my best bet for a replacement pump?? Is there certain ones I should be looking at???
stonyloam
Wow that was fast LOL! Yeah, thought you were out of luck til I saw that you have a 1968 engine, there is no kit for the newer pumps.
dezmond
I have the pump so I would love to just put in a service kit if I could save some $$$
HT32BSX115
Don't waste your time. Fuel pump rebuild kits are something like $25 or so.......It's simply not worth rebuilding an old pump where the savings would be an equivalent to about 20 gallons of gasoline.
You also run the risk of getting a "kit" that is "New, Old Stock" . Rebuilding a pump with an old diaphragm could put you in a place where it fails in a very short time right when you need it.
dezmond
So what style of pumps can I buy for my engine?
Ayuh,.... Hit the link posted by Rick, in post #9,....
