what exactly is wrong with my choke
kennedys
Excuse me if my terminology is wrong . I am new to the world of boating and the trials of it.I have a 1970 evinrude 60hp . Been having issues and working my way through them. Now im stuck.the problem is the choke. The solenoid seems to be working but when I turn the key to the on position it goes down to full choke. Im guessing I have a two stage solenoid because I also have a toggle switch under the key when I pull up on it the solenoid reacts but the linkage doesnt move. Tring to figure out if its the solenoid or the plunger. I've tried to readjust the linkage but whatever im doing doent seem to make a difference
1983 ercoa 21'
I wouldn't think that by just turning the key to the on position would activate the choke unless you work the toggle switch.
what are you trying to figure out here?
are you having problems starting the motor?
F_R
It has a two stage choke. The first stage is activated by a thermal switch when you turn the key on. It should pull the plunger about half way down. That stage serves as a warm-up choke to keep it running until it is warm enough to keep running without it. Then the thermal switch turns off and the choke opens completely. The second stage is activated by the toggle switch and together with the thermal stage, slams the choke fully closed for a cold start. Release the toggle and it goes into warm-up mode. Make sure your wires are not swapped and choke solenoid is adjusted correctly. There was a service bulletin about updating the system, but let's not get into that unless necessary. ​ BTW, the manual choke knob or lever has to be in the center, automatic position.
kennedys
Thanks for the replies. The engine has been acting wierd. It'll work then not work the latest problem was I couldn't go faster than headway speed. I cleaned the carbs. I think I damaged the spring on the plunger because it wouldn't start thats when I noticed the action on the choke.when I pulled the carb off I wasnt paying attention to the plunger.is it possible to screw the spring up The wires should be fine. I never touched them.every thing seems fine except in my mind when I turn the key the flaps should only close half way not completely shut. I could be wrong.dont know if im chasing a phantom problem. Thanks again for the help
F_R
I haven't looked at one recently, but I believe the choke solenoid can be moved up or down in the clamp as an adjustment. But re-read what I wrote. Key on, motor cold, choke should be part way closed. Work the toggle switch and it should close tightly. There should be an obvious difference between the stages. But if the update has been done, nothing happens when you turn the key on, but operating the toggle closes it tightly. One of these systems should apply to yours. If not, you need to check out the wiring (and solenoid coil).
Tim Frank
As FR pointed out, the slide lever needs to be set at AUTO. if you want the emote activation option...I had a '69 55HP which I believe should have the same choke setup.
For some reason, if the front hatch was opened and the closed, it could "reset" that lever and the choke would be OFF/manual.
kennedys
I will try adjusting solenoid thank you. I am aware of the manual choke . The good thing about all my problems ive spent hours staring at the motor. Once I figure out whats normal and whats not I should be all set . Thank you
