What engine do I have?!?
ChapBoater
So I just picked up a 16' Sea King, anyone have any idea what engine this is? I thought maybe a Big Twin 40 but most of the cowlings I have seen are different than the one I have.
Thanks for any help!
Honorary Supreme Mariner
????--------My crystal ball is missing.----------Do you have a picture of this motor ?
ChapBoater
Not that I can find. Still trying to get a pic of the cowling attached but no luck. The boat is a 1963
ChapBoater
Definitely looks like it. Ever done a compression test, if so what numbers do you get? Also do you have cable steering or pulling steering? Got another question as well, do you have a push button start on the engine itself? If you do, how do you turn it off. Havent fired the engine up yet until I do the basic maintenance but want to make sure I know what I'm getting into
bouttime007
My comp was 85 per, but it started every time I needed her to.
I hooked it up to my 1983 SeaNymph with cable steering. Had to mod up a bracket though.
Had the key switch from the original setup, so I used that.
