What does this light means
STRIPPER2223
this gauge is on a 1993 200hp yamaha. can someone tell me what this means. :confused:
STRIPPER2223
Re: What does this light means
i don't know if this lights has anything to do with the lost of power on my motor. i can start off planing @ 42k-46k RPM then it gradually drops to 28-33k RPM and the boat won't plane again. Does anybody knows what's causing this? :confused:
99yam40
Low oil level is my thoughts.
Not enough info on PRM issue
STRIPPER2223
i filled the oil tank and the indicator is on the full side. The RPM would hit 42-46k for less than a minute then would gradually drop to 28-33k.
99yam40
Need to troubleshoot to see if compression is good, if it is loosing spark to one or more cylinders, timing is in spec, or if a fuel issue. \
Also depends on if this motor has ever run properly on this boat
STRIPPER2223
does anybody know where i can get a manual for the gauge?
