What does 6 beeps mean after key ON?
mijangos
I just bought a 2023 Crownline 250 SXX. When I turn the key ON, I hear 6 beeps. It wasn't doing this before. Also, the 12 volt systems (GPS, radio, light, horn) are all OFF an won't come on. I measured the voltage at the main 12V bus bar = 0 volts. Has anybody seen this before? The engine seems to be working OK. Here's a pic of the 12 V bus bar. Where is there a fuse or circuit breaker that supplies it with 12 volts? Any help is highly appreciated!
redneck joe
welcome to the forum.
this might be a better question for an engine forum. I assume it is a mercruiser?
alldodge
Moved thread
Your getting the beeps because main power (Battery switch) is not turned ON of a cable is disconnected. The keep alive power from Bat to ECM is there but that's it
mijangos
Thank for the comments and tips. My son pressed the red "test" button on the circuit breaker next to the Battery switch. I reset the breaker and everything is ON! Yay! I still hear the 6 beeps when key ON. The Digital Mercury engine monitor displays an Alarm: "Trim/Tilt sensor". Looks like the analog trim/tilt gauge is not working. I assume that explains the 6 beeps. I now plan to replace the trim/tilt sender. How easy/hard are these to replace?
alldodge
Don't think that's the issue
Still think it's low voltage. Can also be low drive lube
Which motor do you have, serial numbers are best?
