What do you clean your buff pads with?
ufm82
Master Chief Petty Officer
I've filled up my twisted wool pad with Meguirs #49 and I don't know what to clean it with. Regular degreasing soap did nothing and I don't want to try that much acetone or thinner. <br /><br />UFM82
RotaryRacer
Re: What do you clean your buff pads with?
Let it dry and use a firm bristle brush to fluff it up. Otherwise just some water should help rinse it out.<br /><br />You could also through it in the wash with some rags.
John Carpenter
Put the pad back on the buffer & while running at medium speed, use a screwdriver or similar tool to "spur" the pad. Start at the center and work out to the edge. This should be done regularly during use as the pad begins to load up.
snapperbait
Relentless is right on!... :) <br /><br />ps. wear a dust mask... ;)
bigbad4cyl
only thing that works for me is to wash it in a washer
novicetech
Relentless and snapperbiat are right use screwdirver from center out.
bigbad4cyl
they actualy sell a pad spur;
tolae_1854_821422
; http://www.topoftheline.com/detail-pad-cleaning-spur.html
ufm82
I knew I could count on you guys... That's just what I needed to know. You've helped me a bunch. <br /><br />Thanks all.<br /><br />UFM82
