petermarcus
- Apr 30, 2010
- 129
'94 Bayliner 1950.
I've removed the deck and stringers and seatboxes and I'm 95% down to bare hull. Instead of grinding away the glass tabbing where the stringers and deck meet the hull, most of the glass is delaminating from the hull, and I can just peel it off (sometimes it does need some persuasion, but usually I can peel it by hand). Once I do that, I'll grind everything smooth and start installing the transom, stringers and deck again.
But today, when pulling up some glass that used to be under a stringer, I found bare wood. This wood looks pretty embedded into the hull poly/glass, like it's something structural that the hull was built around:
It's in what used to be the ski locker, under where the stringer was, and seems to be right over a chine. Underneath, I don't see anything different:
Does wood make up the chine in a glass hull? Did I hit something structural? Did I screw up my hull, or can I patch it with glass then grind everything smooth like it never saw the light of day?
