badlockjaw
- Apr 17, 2012
- 11
It's not white, but light brown. There was no water in it, but the color just isn't right. Don't know what to do. Just got done rebuilding dang near everything on it. It's a 69 25hp johnson
Did you replace drain plug washers (seals) when you last filled the gearcase? Sometimes that'll be a leaky point if the seals are shot. I'd re-lube, add new plug washers and inspect it every so often by just removing the lower plug for a second to see how the lube looks. A little water (slightly milky) won't hurt anything, but liquid water separated out (will collect at bottom and will come out first) is not good.
What oil are you using ? Fatzbullet brought up a good point.
I have thesame problem with my 1979 85hp. My mechanic who has been a johmson evinrude mechanic for 30 yrs says change the oil a few times a year and leave it alone.
I dont agree with that but he feels that with a salt water motor your opening a can of worms. I said what do you mean.
he said
the seal surfaces make be pitted, the housing may be corroded etc. He wont put 2 hrs worth of work into a 33 yr old engine and tell me its going to fix the oil leak.
he says he has quite a few gearcases that have been running for years with a small leak, but the key is to change the oil 2-3 times a season if you can.
Part of me says get it fixed and part of me says leave it alone. for now im going to check it in a few wks.
thats my .02
good luck
