What causes the head gasket to go bad.
ajohnson035
I have a 94 johnson 15hp that I just purchased and it is in the shop with a bad head gasket. What would cause the head gasket to go bad can anyone help. THanks
Dunaruna
Re: What causes the head gasket to go bad.
Incorrect tension, overheating, corrosion, age.
jonesg
I'd bet on overheating, causing a slightly warped head.
A worn out water pump must account for a big share of that cAUSE.
And dirty carbs causing a lean cylinder which overheats.
F_R
Honorary Supreme Mariner
Add to all the above, somebody removing the head and reinstalling it with the old gasket.
