what carpet should i use
canman
i am starting to restore a 1986 16 foot larson senza . i have sent the buckets seats and cushions out to get redone ,what kind of carpet should i use , the kind with rubber on the back or the kind with no rubber on the back . thankyou .
zuke1
Re: what carpet should i use
when i redid the carpet on another boat i used to have... i just went to home depot and and got the outdoor carpet, i think it was about 3$ a yard or so.... it looks great, comes with the rubber backing on it, and you can use almost any type of all purpose carpet glue on it...
it was cheap, and it was made to withstand the elements...
and it looked good too...
later
zuke
Chris1956
cnaman, I agre with Zuke. If you can find an outdoor carpet you like at the Home Despot, it will be so much cheaper than an marine place. I actually special ordered a teal carpet ath the H-D. It was still very cheap.
tashasdaddy
i agree with klos, carpet has no place any where except on the bunks. and the new poly covers, should take that place.
You can go to Lowes or Home Depot either one and ask them for a marine grade carpet they have it pretty cheap. I redone my boat, I went to Lowes, I think Home Depot also carries it.
Lou C
None, I am doing mine in Durabak non skid!
Boomyal
....or you could try this type of Nautolex. Here's a pic of my recently redone floor. The original Nautolex (see inside side pockets) lasted over 30 years. Carpet in a runaboat makes no sense. It does nothing but hang onto water and dirt, then look tacky very quickly.
http://www.a1foamandfabrics.com/site/department.cfm?id=11BE5A56-98C1-443E-A01FB5A6B3A61E36
Tail_Gunner
:devil: I just got done searching 20 minutes for that link..........:'(
Zetman
Boomyal, what make of boat is that?
My aluminum boat had outdoor carpet and the floor rotted from being wet most of the time. I have just replaced the plywood. After it was cut to size I put two coats of outdoor primer then a coat of marine carpet glue then another layer of marine carpet glue with a 1/8th thick troule...then the Nautolex $15.15 per yard from this site...
fast shipping also...check it out so far...
Boomyal
You probably see a few of them down your way, Zetman. It is a Gulfstream, now defunct, out of Salt lake City. They were made from sometime in the '60's to mid? 80's. They had 18 and 20 footers.
There is a Gulfstream link in the MFG's forum below. If you should happen to run into a junker, I'm looking for a set of OEM seats, regardless of shape. (cheap)
Boomyal
Save it in your fav's, TG.
tmh
Boomyal, what does that flooring feel like on bare feet? I'm no big fan of carpet either, but there's a reason most boats have it, especially non-fishing type boats. If it feels "plasticy" I think it screams of "cheap". More functional, maybe but comfortable, I'm interested to find out.
It does look clean and neat.
Zetman
Boomyal,
I just bought a 1970 Gulfstream and in the process of re-doing the floor..the seats that came out of it I think are not orginal how can you tell?
Zet
Boomyal
tmh, the floor does not feel like plush carpet under your bare feet but it does not feel plasticy either. It is a very good, firm non-skid finish that does not 'cut' like some of the non-skid additives that you put in paint coatings. Lighter colors stay cooler and darker colors can be hot in 100 deg heat.
When glued down well, it is very durable and easy to flush clean.
Boomyal
Zetman said:
Boomyal,
Zet
Here is a side picture of the molded seat bases that your boat probably came with. IMHO they are the absolute best in the industry. Unfortunately, I think many people tossed them when the upholstery wore out and installed cheap generic seats and bases instead of just having the originals re-upholstered. Except for the risor blocks that I built, these are the original 33 y/o seat bases.
Be sure to check out my Shareaproject tutorial for many aides in redoing your floor.
http://www.shareaproject.com/pages/projectTut,p,92,00.html
Also be sure to add some of your pics to the Gulfstream Archieve forum, here. Start a new topic for your addition. This may end up being the only place on the net that has any accumulation of Gulfstream info.
http://forums.iboats.com/bbBoard.cgi?a=viewforum;fid=182
Tail_Gunner
Boomyal how easy is that stuff to mold around corner's, or can it be, and if it could be, do ya need a heat gun?
Boomyal
TG, I'd have to see what you were referring to. It would have it's limitations as it is a vinyl impregnated onto a fairly tight ripstop woven fabric.
hard-3
Check to see if the carpet is oil and gas resistant. marine carpet is usually resistant , I think the backing material is the problem. Some of the home store outdoor carpet is not fuel spill proof, it may melt or come apart when contacted with gas or oil. I just bought some from a carpet store $9 a yard a 8x16 piece was $100.
Very plush cut pile marine grade
