What’s this line from the engine?
Johaneriksson9
HI guys,
Have a Johnson 25 hp 1985. Reference the picture attached. I have this line that’s coming up from the bottom of the engine and ends half way thru the carburetor. Looks like it should be attached to something but can’t figure out where.
Thanks
Grub54891
Look at the air box, there should be a fitting it goes to, it gets rid of residual fuel from the air box I think. If I'm wrong, let us know.
flyingscott
There is no airbox on that motor. I believe that ties into the primer line that goes to the top of the carb. I think it should be a smaller line and it acts as a primer for the lower cylinder. I could be wrong I would look for the fuel routing diagram fort he primer. But definitely not an airbox line.
Mohawkmtrs
Flyingscott is right. There is supposed to be a tee connector in the primer line he identified. That unconnected hose goes to the tee.
Looks like it should go to the fitting for the top bearing.----Pictures of that area would help.-----Your 2 pictures are not nearly enuff to decide on this hose.
Grub54891
Yup, I thought it had an air box. When I'm wrong, I'm incorrect.... Lol....sorry....
jimmbo
There is a hose up there
Can't post a picture, must be another one of the 'improvements' to the board
Crosbyman
well looking at the parts diagram it does look like the hoses on the side of the 5.5 and 7.5 hp
the hose is used to push oils residues from the lower crankcase back up to the top bearing to keep it oiled.
isn't there a nipple on top of the carb somewhere ?
read the section OIL TUBE TO THE TOP BEARING
http://www.leeroysramblings.com/OMC_6hp.htm
Johaneriksson9
Thanks for your answer. On the picture attached to this answer you can see the fuel line that goes from the primer to the top of the carb. You’re saying that the line coming from below the cylinders should be attached to the primer as well? As of now from the primer goes two fuel lines. One to the top of the carb and one to the bottom of the carb.
Johaneriksson9
Yes there is a nipple on top of the carb.. but that nipple is a fuel line from the primer. And the line you’re talking about, the line from lower crankcase to the top I think I’ve found. Added two more pic to this conversation showing what I think is the oil line you’re talking about
Where does the other end of that mystery hose go ???-----Bring the motor over I could figure it out in seconds.-----Might even be there to feed a water pressure gauge.----Without clear pictures I can not help you.
Johaneriksson9
Here Are three more pics. The line is coming from unterneath the engine/cylinders just aft of the carburetor
Just one more try here.-------Your picture appears to show a hose from the intake manifold to the top bearing.-----The hose from the bottom bearing goes to the top bearing.--Hose FROM the primer splits and one goes to intake manifold and one to top of carburetor.------Someone has this mixed up on your motor.----Be easy to sort this out in seconds if motor was in front of me.----Find a shop to help before running this motor.
Chinewalker
Motor looks like a bit of a mishmash of parts. Powerhead is silver - a typically Evinrude color, while belly pan is white, a typically Johnson color. The hose from the nipple on the bottom of the crankcase should go to the top of the crankcase. Depending on the year of parts used, the hose on the intake manifold should run to a similar nub on the intake port cover on the side.
