Wet sounds sub problem
R422W
I have a huge question, my dad has wet sounds on our Malibu. We have had it on there for a year now, but this Friday we were listening to it the sub was turned up aittle bit.. Then all the sudden it caught on fire. Were still not sure what caused it because we are still at the lake, but I was wondering if anyone else has had this problem?
Silverbullet555
Re: Wet sounds sub problem
Call tim at wet sounds. They will have you send it back and take a look. How many watts were you running through it and what was the setup for the box. Is it an XS-10, XS-12 or XXX?
I had a bad amp which was sending straight DC to the sub and it toasted a wetsounds sub because I did not understand what was happening. Now I know.
replaced the sub and amp and all is good.
Here is what my speaker looked like on the inside.
Mine was caused by a bad amp. Had I known what I know now it would not have happened.
Amp might be fine, but since you were listening loud it could have been clipping which can cause issues for speakers as well.
R422W
My dad said he was gonna take into the place that put it in. I am honestly not sure.. We had a wet sounds dealer put it in an they put in almost everyones wet sounds in down here.. & no one else we know has had a problem. But thank you for letting me know that.
Everything else was fine with the system expect the sub lol, the box melted an they also screwed the sub to the floor so still not sure if were going to be able to get it off.
As soon as we found out the problem I'll let you know if we had the same as you. & thanks again :)
