were to get piston for volvo aq130c
revherup
found a bad piston to day did not hurt the sleave but piston needs to be replaced..does anyone no were to get them or how much there are for 1 piston and rings...
Don S
Re: were to get piston for volvo aq130c
Volvo doesn't even carry the piston kits for the standard bore anymore. They are NLA.
If you bore it .030 over, you can get a piston kit from Volvo for just under $280.
Just one of the hazards of trying to run really old marine engines.
revherup
so there is no way to get piston,that sucks i only need one every other piston looks good and has great compression....
Don S
I didn't say it was totally impossible, I said Volvo didn't sell them anymore.
There is probably someplace in this world that has them. I just don't happen to know that place.
Might give google a try and look for some Volvo dealers that have old parts.
anthony115merc
you should be able to order them through a diesel machanic you will need a new liner because they are sold with new pistons the pistons and liners are made in sets that will only work like that if you go changing a piston and not liner the fit wont be right and you will not have enough compression or **** the liner and piston
Don S
It's a gas engine, and it doesn't have liners.
Starflight
Try http://brickboard.com/ They have all sorts of info. and resources on the old volvos. The aq130 is based on the B20 volvo car engine used from mid 60's to 76. You will be able to find the parts you need.
anthony115merc
oops didnt look at the name of engine just saw the volvo lol
chumslinger
how much can an older volvo engine be overbored? mine is already 020 over..thanks for any info
