We're do I put my fuel line
Newboatguy88
I have a 1980 7.5 evinrude outboard motor. I was wondering were my fuel line connects to. There are to nipple looking plugs on the motor one has 1 hole and the other has two or four small holes
oldcatamount
Re: We're do I put my fuel line
There are 2 fuel lines. The larger one comes from the quick disconnect coupler (where you hook up the fuel tank) and goes under the carb to the fuel pump on the other side of the motor. The other (smaller) one goes from the fuel pump back to the carb.
Newboatguy88
So do i need to have two fuel line and I put some gas into it. The gas drained out does that have something to do with the choke. Does the choke need to be all the way out or all the way in when I try and start the motor thanks for the help
F_R
Honorary Supreme Mariner
What in the world???? There should be a fuel connector similar to this. Your tank hose clips to it. Another hose is permanently connected between this connector and the fuel pump. And then another hose permanently connected between the fuel pump and carburetor.
You choke it to start a cold motor, open the choke when it starts.
oldcatamount
The fuel line comes from the remote tank (where you put the gas) and connects to the coupler on the side of the motor. From there, it goes through another fuel line to the fuel pump. The second fuel line then goes from the fuel pump back to the carb. Yes, you need both lines to run the motor. The choke needs to pulled out (closed) for the first one or two pulls. When the motor starts, push the choke knob back in.
Newboatguy88
Ok my new problem is I try to connect my hose but it keeps on popping off
oldcatamount
Push it a bit harder. There's a "clip" that engages the coupler and holds the connection together.
barrynfla
When the clip engages, you'll definitely hear and feel a "snap." It's the same connector that's on your fuel line that connects to your gas tank. Don't forget to keep the vent open on your gas tank.
Newboatguy88
Ok I guess I have the wrong fuel line can someone post a pic on what it looks like. Because I have a clip but there is nothing to clip to
nwcove
F_R posted a pic of what the clip clips to, its the pointy prong on the left of the pic, the clip locks into the groove in that prong.
Newboatguy88
Got it hooked up. Now my fuel line pump is not pumping gas what's wrong now could it be blocked up
