Rick K
Thread starter- Joined
- Oct 6, 2003
- 235
Hi,
This is a little long, but I want to give as much info as possible.
Was wondering if someone might be able to answer a question on prop pitch... Read all the stickies, and did my research, but looking for someone to confirm.
Running a 15 foot Starcraft Jet, closed bow runabout. Approx weight with 2 people and gear, maybe 700-800 lbs(?)
Had a '76 Evinrude 25hp with a 9x10 prop that did very well. Up on plane quickly, decent top end, all around good prop. Wasn't a speed demon, but did very well for that little motor.
Swapped up to a '79 Evinrude 35hp that has a 10x13 prop. Boat doesn't plane very quickly, engine seems to take forever to get up to top rpm's, etc., and doesn't plane as well as the old 25 did. It is definately faster than the 25, but again, seems to take quite awhile to get up there.
Question: Should I go down to a 10 pitch prop to match what I had, or drop down only 2 points, to an 11 picth. From what I've researched, you should try going up or down in 2 pitch increments Will the 10 pitch on the 35 give the same performance and the 25 did (perhaps a bit better given 10 more hp?), or will it just scream the motor and not really do much at all?
I'm thinking to go to the 11, as the 10 might be a bit drastic. Tiny Tach is on order to check the r's, etc.
My goal is to not have the fastest boat around but would like to gain the best top end I can. I understand about propping out to match the rated rpms, but was thinking someone here might have some practical experience.
Any insight is appreciated.
Thanks
Rick
Thanks
Rick
