Re: wellcraft 236sc info
Wellcraft can be a little funky on their model years. For example, my 1991 has a 7.4l engine with a Bravo 1. All the info I can find shows that combo not being available until 1992.
So your 1993 Eclipse 236SC, could be the same as the 1994 and was just an early build. Or it could be the older Eclipse 233 model badged as a 236SC.
You can find the model info guides at
http://www.wellcraft.com. Just click on the 'Owners' link.
If it's the newer model, then yours should look like this.
If it is actually the older 1993 Eclipse 233 model it will look like this. About the same size but with more squared off lines.
