Welding starter mounts volvo 4.3GL 1999
darrell.1
Hello everyone. Well my starter was making a loud grinding so took off starter and checked it.Starter fine, When i installed the starter I noticed the closest bolt hole is cracked on the block in 2 places. when I turn the boat over the starter jumps and becomes loose again. I have 23 questions please. Thanks for any advice. I have heard it all and nothing good so far. haha
3 questions please.
1.Can I weld the Cast Iron cracks on block?
2. Do you think I have to remove the motor to weld the cracks.
3.Can i use longer bolts and locktight and just tighten the heck out of it?
Marina wants $1,500.00 to look at it.
Thanks
Darrell
darrell.1
Hey everyone. I have a 1999 Monterey volvo pentum 4.3 GL.
The cast iron block where the bolts that hold the starter in place are cracked about 1 inch from base up.
Can I weld this?
Must I remove motor to weld this?
will welding hold the starter in place. starter jumps and grinds right now and loosens bolts after 2 starts.
Re: Welding starter mounts volvo 4.3GL 1999
Can I weld this?
Ayuh,... Welcome Aboard,... Donno if You know how to weld cast iron, or not,... I can....
But,... I wouldn't even Try to do that without pullin' the motor...
Cast iron needs to be either Brazed, or welded with Nickle filler rod...
'n even then, the odds are against success...
R Steele
Re: Can I weld cracks on starter mount.
I've seen someone break the corner of the block off by putting in too long of starter bolts into a closed hole and tightening too much. Could possibly be why you have cracks now.
Dpierovich
This is a fairly common problem with these motors. I've read several posts on other forums with people taking about the same issue and have seen a few local motors for sale on CL (cheap) with the same cracking. I noticed mine had small cracks when I replaced my started recently. I was careful to torque the bolts back to Volvo specs and will continue to check it before going out. If it only makes it another season, at least I can put off the repower a bit.
I can only guess, IMO these engines were probably overtorqued at the factory. THANKS GM
Ayuh,.... Welcome Aboard,.... You can increase yer odds abit by puttin' a front brace/ bracket on it, back to the block,...
bruceb58
Old Thread.
OP hasn't been here since last May.
