Weird stereo issue
dave181024
I installed a new Stereo into my boat to replace the one i had; old one did work but it was old and just wanted something newer. Radio works flawlessly when i tested it on the trailer but when the boat goes in the water the radio doesn't work at all. I'm so lost on this one. Any ideas what it could possibly be?
chrclo
Re: Weird stereo issue
Interesting. What kind of boat/stereo? How do you have it wired?
fletcher123
Would need more info on your radio problem. like it doesn't turn on at all,no power? or stations just don't come in when on water? trying to listen to it when motor running or when motor turned off? Would need to know what wires are tapped into and know what the exact problem is.
dave181024
its a 21' donzi....wired same way the old stereo that was in there was
dave181024
When the boat is on the trailer on land the radio works fine, radio Stations work, USB input works, Aux works (both with motor on and off). Once the boat goes in water the radio doesn't even turn on and seems like no power. Even when i stop the boat in the water and its sittle still...nothing.
I had a radio in there previously and i wired it up same exact way all the connections b/w wires are good and antenna wire is perfect...
pheasanthunter
take a test light or a multi-meter and test for ground and 12 volt power when it isn't working is the first place to start. If you just have a Test light. hook wire to a known good ground and probe power wire to see if you have power. Then you can test your stereo ground by using that power wire to see if your ground is good.
A multi meter would be better. Then you can test for voltage and voltage drops on wires to see if your wires are bad. They can corrode internally and not supply enough current to power things up.
