Weird overheating issues
Backyardmech
I have a 2001 vp 5.0gl. It recently overheated due to bad impeller and raw water pump. After replacing the raw water pump and while running on the internal water hose directly to the raw water pump the water flow through the exhaust would stop and all the water would divert through the lower water intake ports in the out drive. Significant water was in cylinder 3 so I pulled the heads and one head gasket was blown. I took that head to the machine shop and they found that it was cracked. I replcace the head with a one rebuilt by the machine shop. After installing that head with new gaskets and thermostat everything seemed fine. Water flow out of the exhaust was good at idle and medium rpm. After doing several cycles medium rpm for a few minutes and idle with the temp fluctuating between 150 and 165 I let the engine at idle for about 20 minutes while I was looking for hose leaks and listening for odd sounds. While poking around a hose felt too hot and the temp guage read 200°. I shut down immediately.
Tldr.
What could cause the temp to spike after idling for 20 min after being cycled between med rpm and idle for about 30 min with no overheating issues? All on internal fresh water hose directly to to raw water pump.
Lou C
Did you have the head on the opposite side checked for cracks?
Backyardmech
I probably should have, but no. I didnt notice any water in any cylinders on that side. I have replaced both head gaskets.
alldodge
Connect a short clear piece of hose between thermostat and hose coming from pump. Boat needs to be in the water and your looking for bubbles
Backyardmech
Any thoughts on what else could be the cause besides the head?
I would like to eliminate everything else before taking th head back off.
Backyardmech
Any idea of tests i could do on the hose?
Im not real close to a usable body of water.
Lou C
Often when one of these engines overheats, not only do the blow head gaskets but they will crack the heads. On some engines (I had this happen) they can overheat and then seem fine for a few seasons, but sooner or later the head gasket fails. I had that happen (water in a cylinder) 3 seasons after an overheat, when I took it apart I took both heads to the machine shop and both had cracked valve seats in the center cylinders (4.3 V6). So based on that and the fact that with saltwater use, the cooling passages were getting pretty eroded, I replaced the heads with a pair of reman cyl heads. Put it back together with Fel Pro gaskets and ARP cylinder head bolts and it is still running well now 9 years later. The best test is the one described above, where you run clear hoses from the thermostat housing to the exhaust manifolds, if you see bubbles coming with the water after the engine warms up, you are getting exhaust gas in the cooling water. Problem is, even if you do that, you still don't know the exact cause, it could be a blown head gasket (depends on where it blew) or a cracked head or a cracked block. You still have to take it apart!
I rigged up a way to do it on the water hose, it has to be done fast because the way I did it, engine isn't getting as much cooling water as normal but the manifolds are, I removed the thermostat temporarily to allow max recirculation of water. This was like 10 years ago so I may have forgetten some of the details. Watch it to the end, when I turn the engine off, you see bubbles in both funnels, that is exhaust getting into the cooling water, I knew it was at least head gaskets. In this case I didn't have water in the cyls where the cracks were but in the end, the answer is the same, finding the cause requires a full tear down.
if you can do a test in the water it is a much better test.
the cure:
Does your spigot put out 10-15 gpm? Is your hose 3/4" or larger?
If one head gasket went, the other should have been done as well
Backyardmech
2Xs with SD and did you find the all the impeller pieces?
I have not found any impeller pieces for certain. Im about to take the thermostat housing back off to to check if any are clogged in the thermostat or manifold water supply ports.
Backyardmech
Both head gaskets have been replaced (the right side twice now). I pulled the manifold and engine water pump hoses off of the thermostat housing. The large engine water pump hose was full of water and water ran out of the housing. Both manifolds were dry of course.
Backyardmech
the cure:
I pulled the manifold and engine water pump hoses off of the thermostat housing. The large engine water pump hose was full of water and water ran out of the housing. Both manifolds were dry of course. If the other head was cracked and pushing exhaust into the water jacket would the water level still be up into the thermostat housing?
The thermostat housing is set up as a mixing valve. It should always have water flowing out the exhaust and sometimes have water going to the block and heads
There is a bleed orifice in tbe housing that vents air bubbles
Is the thermostat installed correctly?
Did you acetone test the manifolds?
Did you pressure test the cooling water jacket?
Backyardmech
The thermostat is installed spring down, which I belive is correct. I have not pressure tested the water jacket or acetone tested the manifolds.
Wouldnt I get water in cylinders if the manifolds or risers were cracked? I havent seen a bleed orifice on the housing. Where is it located?
kenny nunez
Seperate the risers from the manifolds inspect the mating surfaces, they should be smooth with solid material where the water passages are divided from the exhaust gasses. With the riser inverted fill the water side with acetone and the manifold body as SD mentioned.
If you have a friend with a blast cabinet have internal side blasted clean, or be sure that the metered orifice and other passages are clean.
Lou C
You have to test the manifolds and elbows as Kenny stated. You can have an external crack from a lack of winterizing that will leak outside but not inside or vise versa. Or, if it's the wet joint exhaust, you can have water seeping in around the joint between the elbow and the manifold. I use an endoscope inspection camera to look inside mine now at the start and end of each season. That way as soon as I see any sign of water inside I can take care of it. If you see rust trails on the outside chances are it's also leaking on the inside. The exhaust on my engine is the OMC/Volvo later style and has a plug on the top of the elbow for an exhaust temp warning system that I don't have, I remove that plug and the camera fits right in that hole & you can see this:
Backyardmech
Update:
I put sections of clear hose on the raw water pump and exhaust water lines.
At idle there were no bubbles coming up the raw water pump hose although when increased rpm there were several bubbles. I assume that due to inadequate capacity from the water hose. There were constant small bubbles through both exhaust water lines. I am planning on pulling the starboard head to have it check like i should have done in the first place. I will update again after I have a head reinstalled.
Thank you for your advice lou.
Backyardmech
Update:
I put sections of clear hose on the raw water pump and exhaust water lines as you advised.
Thank you for your advice.
