I've got thisold 50hp electric shift Johnson. Bottom cyl has 0 compression.<br /><br />If I put my air hose on it however, it leaks out the carb. When I turn the flywheel, it closes and there is no leak.<br /><br />Now. If the cyl was dead, you'd think it would leak down exhaust, out head, etc.. 125psi air hose. But it doesn't. Yet you crank it all day with the electric starter, and no compression on that cyl.<br /><br />Any insight?? <br /><br />-- Joe
